Seadogsx1997
1997 gsx Hi I've had carby issue well I think I was stalling in water at idle after a while then flooded when park so I rebuild my carbys again using mikuni rebuilt kit and new needle and seat order 2 black 80 gram springs bought a pop off tester pop off is 38 psi not leaking put back together now will only start with choke and up down stall on trailer I've gone backwards any help would be appreciated as I'm giving it one more try then I'm buying new carbys and hope that's the problem but I'm. Not sure also just did too end rebuild and 158 psi on both
