Can't get my Sea Doo to start
Tonyt23
I think it's the fuel pump not sending enough or no gas to the carburetor if anyone knows how to fix or can send me a PDF of the specs of the Sea Doo that will be great thank you
If you are referring to the ski in the avatar, I believe it is a white 587 engine. There is no fuel pump. try spraying a gas/oil mix in the carb intake. DO NOT use starting spray. There is no oil in it, and will ruin the engine.
Make sure the lanyard is attached, and the plug wires are also attached.
Rebuild your carbs. Replace all your fuel lines. Read the Seadoo carb rebuild thread.
