Just purchased this 98 xp limited and I missed a few things when i purchased it. Under the rear hatch when installing the new battery I noticed the the past owner had the bilage pump hardwired to the battery and had the ground wire hooked up to just unplug from the battery when not in use. I would think the bilge pump would either be automatic when water is detected or when power is on and ski is in use. Above the pump in the factory wiring harness I see a plug that has 2 wires that are spliced and just hanging down. Anyone know what these go to? Maybe the bilge pump? I will try and attach a picture.
