"12 v low"
Hello, just wanted to add, I too have a 1998 GTX Limited. I' m have the same problem as Jayele.When you first start it up it will flash 12 V LOW for 3 sec. Bought new odyssey battery still flashes. Battery test at 12.8 volts not running, then when I start it, jumps to 14.3 volts(normal). Sea Doo dealer told me the late 90's 951 engines will do that "no big deal" . I don't buy it! Because when it sits for two to three days the battery will read 12.4 volts (12.8 is full charge for my battery) 85% full. Then when I go to start it, put on the lanyard no beeps at all, But it starts right up. Then it will charge up on its own. There has to be something draining the battery. It sure seems like alot of people are having this same problem, and replacing rectifiers, batterys.., When I really think there is something else going on with these models. I have not figured it out yet, Mine does have a bad speed senser that I'm replacing it on 8/3, but I'm sure that has nothing to do with it. I'll continue to work on it and see what I find.
