Bailer tubes
gbownva
question their two plastic hoses coming from under neath Nozzle,I had to replace the fitting where the pump hose hooks to and the two clear lines my question is does it matter where them two hook on the new fitting ? please some help thanks
Can you tell me what boat you are working on? I don't recall any clear tubes on my boat or Sea Doo PWC
2011 GTX 215 iS had to replace a actuator and had trouble with the removal of screw so ended up replacing the backing plates and then a hose barb broke and had to replace what they call a fitting so I ended up replacing both plates all new O-Rings and now in the process of reassembling and not sure on what barb the two clear rubber hoses that they call bailer hoses go ? Out by the jet nozzle
This is the boat section, not the PWC section. You may have better luck if you post your question in the PWC section.
