Hey all - long time no see. Hope you all are doing well in these COVID times. Me? I'm still paddling my 96 single-engine Seadoo canoe. Its a Challenger with 787 engine. I need some advice.
I just had carbs cleaned in and still having what I think are fuel issues. Prior to the carb rebuild the engine would not idle. It would fire off and run for a sec or two and then die. It sure seemed like a fuel starvation issue to me. Carbs are now cleaned, installed new plugs and engine idles fine but has low power, will only do 10-15mph. Attempting to go to full power will bog down and die. Both cylinders compression check at 130psi
My boat tech tells me my fuel selector may be restricting fuel to the carbs. He recommened I check this by temporarily bypassing the selector. I can blow thru the supply line and get bubbles in the tank but it does require a little effort and does not seem like a free path. Have you all seen the fuel selector create a problem in restricting fuel to the carbs?
