PJ Moran
My '06 GTI got caught in a severe thunderstorm and was repeatedly slammed against a retaining wall and up under a dock. The hull is damaged and the boat took on some water. But, it did not sink. However, it was listing badly by the time I was able to safely get it back onto a lift and drained.
I find no water on the oil dipstick. But, after reading several posts on here, I also pulled the intake manifold aside for inspection to find that it is full of water. Some water got into the intake area above the valves, but there's no standing water - just some droplets. Did a little splash in there? Did a bunch slosh in there? I don't know. I just know there's some moisture.
The instrument cluster is gone (lost in the carnage). The start button is gone. So, I know it won't run, but I can't even crank it in flood mode.
I'm trying to sell the wreckage to someone interested in the engine, but I can't figure out how to tell if it can be easily resurrected. Is there a way to "jumper the solenoid" like you used to could do on older cars? I need to see if it's "locked up" and/or there's water in any cylinders. I imagine any "standing" water would have made its way past the rings by now, but I still want to make sure it turns over and see if anything is spit out the plug holes.
I think I have identified the starter solenoid. There's a two-pin connector with smallish wires (brown/yellow and purple). If I apply 12v across those pins, will it crank? If so, which one is hot and which is ground?
I've read too many posts that say, "Take it to the dealer" That's not an acceptable option, to me. 1) There's not one nearby and 2) I can't see spending hundreds to a shop to tell me whether the engine is junk. I can't make any money doing that. I need to be able to assess this myself.
