Accelerator Pump Check Valves
Atomic
I am currently rebuilding a BN-40i-38 carburetor for my SeaDoo 2001 GTS 5521. Below I have a picture of the bottom of the accelerator pump. I know for sure one is a check valve and it's working, but I'm not sure if the other one is a check valve. Can someone please confirm?
The check valve will be in the small fuel line from carb to pump
Thank you, but now I have another question. I took this brass fitting out of the carburetor because I thought it was threaded in, when it was actually press fit. Can I push it back in and use some 592 thread sealant to seal it back in place, or is there something else I should do?
Damn..screwed the pooch now, slick... Can jb weld it in or just eliminate the excel pump and go up a jet or 2 on the pilot....
