Redsled Member Aug 22, 2018 #1 So this code is what is on my 99 gtx rfi Code says crank position sensor no signal detected when ignition is on but engine not running. So does this mean. Replace sensor ?
mikidymac Moderator Staff member Moderator Aug 22, 2018 #2 I would check all wires and connections as well as the sensor to make sure there are no metal shavings on it before replacing.
Redsled Member Aug 22, 2018 #3 I took sensor off there was a few small fillings but not many. I will check the wiring tmr. Thx.
