Very easy to remove and clean.
Place a container below the quick connect fitting of the fuel rail. Cover the quick connect fitting with a shop towel.
Press on both tabs and disconnect the quick connect fitting.
Disconnect the wire connectors on both fuel injectors.
Loosen both screws retaining the fuel rail to the cylinders.
Remove fuel rail with both fuel injectors.
To remove fuel injector from fuel rail, pry off the retaining clip.
When reinstalling the fuel injector, install the retaining clip to the injector then insert the injector to the fuel rail.
