PWC: 98 GTS (717 Rotax)
Problem: Ski will start with mix added manually to carb, but will not run. I have isolated that fuel is not getting to carb.
As background I have rebuilt the carb so the fuel pump is not the issue. I have blown out the lines and they are clear. I have cleaned the selector valve. The inline fuel filter is clean. The check valve is working and the system holds pressure.
So, the feeder line is not getting primed which usually indicates a bad diaphram, a blocked line, a clogged filter, a clogged valve or the system not holding pressure, but all of these check out.:banghead:
Oddly, when I blew into the return line, it pressurizes the lines but no gas is advanced into the feeder. I know this is usually the way to check this. And yes, there's gas in the tank.
It's not full but it has a few inches of gas in it. When I release the feeder line, only air comes out the the system decompresses but it's not sucking gas. So, what am I missing here?
