I just picked up this ski. Dont know history. It has a primer kit and choke cable is disconnected. Looks like aftermarket air intakes on carbs. Starts and revs fine on trailer. Fuel lines are black automotive line except the last foot on the return to tank is still gray. Starts in water and runs up to just below 4k rpm then will die. If you let off quick it will keep running. If it dies it starts right up but wont rev past 4k. New plugs, no change. Seems to run rough below 4k. Fuel filter under hood is clean. It is also taking on water. It is missing one siphon tube in pump venturi for the auto bailer. Didn't look like shaft seal is leaking while idling at doc. Hull had about 4 in of water after messing around with it for about 15 min. What to check next? Running on one cylinder? Rave valves? Fuel selector sucking air? Carbs or carb filters? Rectifier?
