i have replaced the complete driveline on my seadoo, bought the shaft alignment tool, and still this thing eats bushings, any suggestions? anything would be appreciated
Check pump bearings! May need to be replaced! If you have engine line up tool and did it correctly you shouldnt have any problems! is this a carbon driveline kit!
i have changed the pump, complete. the red bushing at the steady bearing is good, i put a new plastic shaft centering bearing, the problem is the red dampener at the motor, i am going to pull the pump and check the alignment one more time maybe i was on glue the first time i did it
