i got a new rebuilt engine after for the port side.
my old one was done for after a bad bearing.
the old engine jumped between 4500 to 6500 rpm back and forward
got the rebuilt engine.
-swaped the carb from old to the new engine
-swaped stator but used the new flywheel whichh came with the rebuilt one
-and the timing of the rv is set as factory. and doubles checked it with the working starbaurd engine.
now it back fires from carb even in ideal
-switched the carb from the working enine to the port side
-rechecked the rv valv
-cut 1/4 of an inch of each spark wires
-new spark plugs
still same problem.
the carb i swaped from port side to starboard works fine.
tomorrow i will check the flywheel is in right place
and swap the egnition coils.
any other suggestions????
thx for any help or ideas any one can give me
-new spark plugs
still same problem.
