97 Seadoo GSX No Spark
Hi everyone,
Sorry! This is a 1997 GSX I typed it wrong the first time!!
I have been digging around in my 97 Seadoo GSX for about 2 weeks now. About a year ago this Seadoo almost sunk due to a leaking bolt in the rear wall... Long story short the starter box had water sitting in it for about 6 months... Yah sounds pretty bad right? Anyway, we have replaced the starter starter solenoid, and the Ignition coil and we have cleaned or replaced all of the connection points within the starter box. When we attach the factory key and press the start button the starter turns over normally, however the spark plugs do not fire. We have been using a spark plug tester to verify this. Here are all of the things we have tried:
1) New starter solenoid
2) New ignition coil
3) Checked every connection within the starter box
4) verified that the black cable leaving the starter box is connected to the battery...
5) Checked the ground bolt on the top of the engine block to insure a proper connection.
6) I have even grounded the engine block with jumper cables... Still no spark.
7) we have verified that the spark plugs are in good condition and we have even swapped them with our working jetski.
8) new battery --EDIT-- Road Runner Power sports battery with a CCA of 325. Its a non-spillable AGM.
9) The computer was properly sealed inside its box and no water has entered the computer housing.
10) I have also checked all of the fuses.
Here is the kicker, while the starter is turning the engine there are no sparks, HOWEVER the split second after I release the Start button there is a single spark as the engine comes to a stop. Which leads me to believe that the engine is properly grounded and also that the flywheel and magnitio system are functioning. I am going to feel really bad if someone is like google "" and its something simple and noobish. I would really appreciate it if someone could point me in the right direction, because I have no idea where to go from here.
Thank you,
Jarid
Hi everyone,
Thank you,
Jarid
