97 Seadoo GTX 800 bogs at WOT
Susie-Q
Hello I am a newbie here and to jet ski as well. I bought a 97 Seadoo GTX 800. I have read so much on these threads trying to fix my issues. So I thought I’d post the problem and try to list all the things we have tried so far. When I first put it in water it idled fine took off fast to WOT got up to about 54 mph for maybe 2 min, then it started to bog if I let off the throttle it would stop and go again. The problem continued to worsen until it was barely above idle.
It did have the gray temp fuel lines. We have changed all of them. It has a new battery and new plugs. Cleaned the carbs the tiny filters were real dirty We did notice oil coming from rave valves. The o ring had slipped and one of them was missing a spring so we cleaned up rave valve some what. My son did it not sure how detailed cleaning he did Got the O ring placed correctly and bought replacement spring.
We put it back in water much improvement but not where it should be top speed about 40 and it takes off fast but a min or two at WOT it bogs it has died a time or 2 if you don’t try to WOT it does fine. I am hoping that someone can direct me what to check next. This is freshwater Jetski I read that someone had a water hose collapse at high speed I’m not sure what that means or how to check this or even what it looks like. Any help would be truly appreciated. Thank you
