97 Seadoo GS not running in water please help...
tjones823
so i've done tons of work to this jetski.. and was really happy that it all worked out... hooked up hose and she ran like she never has before.. clean idle and everything.. revved up high rpms perfect i thought i was good to go... then i put her in water start it up and she idled around.. i apply some throttle and bogged down wouldnt go over 15 mph with throttle all the way in... im to the point where im about to just go finance a new seadoo D:
Try running the in line to the carbs directly from the fuel pickup,,,to help eliminate fuel starvation issues up stream in the pet cock...If this does not clear the problem, most of the time it is a blockage in your carbs,,,although a bad charging system can also replicate those symptoms.
Charging battery it was almost dead, I had to tighten some screws on the outside bracket that holds throttle cable in place.. testing again tomorrow. Cross your fingers
