CRei Active Member Oct 4, 2019 #1 Sup everyone, so RAVE valve broke, guillotine hit piston broke rings, so looking at top end rebuild since engine is only 3 seasons old. Where’s the best place to pick up a gasket set for engine and RAVE valves?? Thanks
CRei Active Member Oct 4, 2019 #3 That’s a good idea I’ve looked but is the a certain brand of gaskets to use?
IDoSeaDoo Well-Known Member Oct 4, 2019 #4 eh, only gasket that matters is the base gasket. You have to get the right squish, so the number of holes in the base gasket actually matter.
mikidymac Moderator Staff member Moderator Oct 4, 2019 #5 I have had really good luck with the WSM gaskets from PWC Muscle here. As IDoSeaDoo said, you have to check the squish for the correct base gasket.
