cloudmaster_321
97 gtx charging question. Got everything back together after changing the starter. Starts and runs at 3,000rpm on the hose. My volt meter is indicating 13.2 volts at the battery. Not seeing anything higher than 13.3vts no matter the rpm. Checked the red wire out of the regulator and I’m getting 14.5volts when back probing with engine running. Pulled the fuse back by the starter selenoid. Checked for amp draw with and without the front 15 amp fuse pulled. Engine draws 1amp when running, and when I put the front fuse in I see 7 amps charge. So why the voltage drop at the battery? Is it just because it’s pulling 7 amps? Looks like max amperage output per the book is 5 amps 6,000rpms.
