Hoping to find an experience oil leak expert!!
97 GTS with oil pooling on the engine cradle. From what I can see and feel, I believe the oil is leaking from the carb side of the engine. The case fitting on the bottom of the engine seems to be intact and not too terrible oily however, when I feel the bolts right above this fitting I get a nice coat of oil on my fingers. Since liquid usually flows down and not up, I thought well it couldn't be the fitting for the case. So what else could it be? The rotary valve gasket? The oil pump gasket?
I have checked all the lines to pump at tank etc, all are free from oil. The ski leaks when sitting. It has sat all winter leaking and I have only lost about maybe a pint of oil if that much.
