RocketFox650
1997 GSX 787 Parked in perfect running order. Installed a new battery for the season as a prelude to beginning any preseason maintenance I could find. A junk battery on a second ski meant the GSX was used to jump the other last summer until the battery fried and wouldn't allow it to run again until changed. Since the batteries were the same age, one was bad, the other only about 75% capacity at best, I swapped both with new ones that actually happened to be higher capacity. The broke down ski fired right up with zero out of water issues. My GSX now won't start. With the key in my display comes up correct, the VTS buttons click like a circuit closing so it's getting power there (old owner removed it when it broke and set the jet level like the SP that's stationary), and the display buttons work as designed. The start button however does nothing. I can jump the solenoid and crank the engine without any problems, the fuse there is fine. With the key in and starter jumped, again the engine cranks without issue, but there's no spark. I found another bank of 5 fuses were found under the dash, the 2nd from the top (7.5) was replaced and the other 4 are fine. I can't figure out what isn't functioning here. I've read posts of people's button having to be wiggled around or pushed in different spots until they got a spark with the cranking, but it doesn't make much if any sense to me tbh. It seems like that should just be a switch that sends power to the starter at its simplest description. Please, someone chime in. Finding references to my specific ski is hard enough. I'm having a hell of a time with jet ski specific issues in general and every one I'm actually having is something that doesn't make logical sense. I'm about to order parts and every one on the list is a replacement for a system that isn't working but isn't broken but if the originals are no longer there they can no longer do the thing that is happening, logically making problems go away. It's expensive and I'm not solving anything really having never figured out what was even happening.
