Oscar_2205
So I have 1997 gsx 787 that o changed all fuel line fuel selector and filter with a good carb rebuild kit I took it out starts up good Idels fine but once you hit the gas it won’t go past 3500 and starts to bog Down and die if you can play with the choke can get to top speed but once off the gas will bog down and die idk if it helps but when reinstalling the carb I belive the oil tentioner line that connect to the carb came in done I’dk if it’s running too lean have good compression in bolth cylinder idk what this could possibly be run and revs fine on the trailer once In water starts to fail
