Barky_Dog
Hi All,
I'm hoping you can help me with my 97 SeaDoo GSI. Late last season I had to tow it off the lake because it started running really poorly. It basically lost all power and died. I was able restart it, but it barely ran and would backfire through the carburetor if I tried to rev the engine. Since the season was almost over, I winterized it and put it away.
A couple weeks ago, I pulled it out to see if I could get it to run. I was able to get it started and I ran a good amount of SeaFoam through it. I took it to the lake to test it, and it ran fairly good for about 15 minutes. I turned it off when we stopped at a cove. When I tried to start it back up it was back to barely idling, no power, and backfiring through the carburetor and then dying.
So my question is- where do I start in order to fix this ski? I rebuilt the carb a couple seasons ago. Should I do it again? I also read that the issue could be because of bad crankcase seals. That this is causing the backfiring.
What do you guys think? Your advice is greatly appreciated!
Barky
Barky
