I haven't used my low hour '97 GS for about a year (before that it started instantly and ran well). I don't have a battery installed in it now but hooked up heavy duty jumper cables from a charged-up golf cart battery, (which starts the cart fine), and I get 2 beeps from the DESS when I plug in the key, but when I hit the start button, I get a very loud click, more like a clunk, then, a long beep. The engine is not turning over (rotating).  If I pull one or both plugs and do the same, the engine spins at what sounds like a normal starting rpm, so the engine is not seized or stuck. Trying to start it after replacing both plugs just gives a loud clunk again, without the engine spinning. Each time you remove and replace the key you get 2 beeps and a loud clunk on hitting the start button, followed by a long beep. But it spins if I remove a plug again.
Looking into the cylinders, they are not flooded or hydrolocked. Should I spray any lube or oil in there to loosen things up a little?
Is my battery weaker than I think and does it not generate enough starter torque to turn over the engine while generating compression, or is the Bendix drive on my starter getting stuck and hanging up, or is there something else going on?
How do I even get access to the Bendix drive if that's a problem? Have to take the starter out?
First thing I have to do when the weather clears is to measure the battery voltage and make sure that it's fully charged, but this battery starts the cart and is at least twice the size of the ski battery so it should have enough capacity to turn over the ski with the plugs in.
Any suggestions would be most appreciated. Thanks.
