97 1800 challenger one engine cuts out at 6500 rpms
dominator
I have a 97 challenger with twin 110s. Both engines run fine to 6400 rpms. The starboard motor starts to cut out at anything higher. At W.O.T. the starboard engine will stall. Cleaned both carbs and switched them out, no luck, still have the same problem. Any suggestions?
starboard motor loses power pass 6500 rpms
Thanks to all for the suggestions. After reading this forum I decided to change the 3 month old in line fuel filters. Even though they looked good and were fairly new, that was the problem. Lesson learned is to check the obvious first. Thanks again for everyones help.
