I am in whack a mole this spring with getting this Seadoo running. Last fall it ran great before I put it away First I got nothing as if no battery. Found a blown fuse in the MPEM box. Then the starter would not turn over the engine with plugs installed. Replaced starter. On the first crank the engine started, only ran a few seconds since I was in the garage. I pulled it out and started again. Ran a little bit then died. After cranking a bunch of times it fired again, but then died again. Now it will not fire. I have pulled the plugs and they looked wet. I then checked for spark and there was spark. Although one plug was weak I would expect that would only cause it to run rough even if that cylinder was not firing. I had one new plug on hand and tried it and still not running.
Any ideas or things to troubleshoot?
