ZX654
Greetings... I am in a pickle.
Backstory: I bought my '96 XP a couple of months ago in a non-running but good condition. I had to take the engine out and drain 2-stroke oil from the bottom of the case as it had been sitting for about 2 seasons, and oil leaked past the crank seals. Well, I put everything back together and found out I have no spark (this was about 3 months ago).
Diagnosing: Since then, I have gone through this ski time and time again, testing everything I possibly can using the service manual or online sources. I'll just go ahead and list everything I have done. Tested the stator and trigger coil, verified trigger coil bracket is intact, tested the dess post, tested the holder relay, tested the continuity of every related wire, tested the CDI (inconclusive), MPEM HAS TWO BEEPS, bought new battery and made sure it's above 11v when cranking, fuses checked, ignition coil replaced, rectifier replaced, cleaned all electrical connectors, mega cleaned the grounds going to the bottom of the ignition coil, changed the starter relay. I have tried many little tricks that I have found in the depths of other forums, but to no avail. Something to note is that the main battery ground has been relocated from the starter to the cylinder jug, I was told this was fine, but I know OEM is to the starter.
Current state: As of today, I have found that I have a signal (using a 12v test light) all the way to the ends of the ignition coil wires. I also have a pulsing signal from the white wire going to the coil. Plugs and plug boots have been removed, and I have tried to get a spark by putting the bare plug wire next to the negative battery terminal, but there is still nothing. In conclusion, I get a signal at the very end of the system, but still no spark. If anyone has had a similar issue, I would love to hear how you fixed it.
Thank you
Thank you
