96 xp No power past 1/3 throttle
RWDAddict
So when i first took it out it ran fine until it warmed up, it sat for many years. I drained the gas and put new gas before taking it out, along with the 2-stroke oil. After it warmed up anything past 1/3 it would sputter. So i'm thinking carb rebuilds. Did that along with putting all new fuel lines on since those were stock. Today took it out same problem but this time the gas light (needs a baffle that's always on), the oil light and battery light were solid. Then the overheat light was flicker dimly as well. I stupidly didn't put the plug in the back so that didn't help. I didn't take it out long. pumped it out and still having the problem. I would say i caused a new issue if it didn't act the same before the water. Seems electrical, so rectifier or MPEM perhaps?
