Last weekend the ski was running poorly, kept fouling the rear plug and running on one cylinder. Thinking the carbs were extremely dirty and having the graylines, I replaced the fuel lines and cleaned the carbs. Did not change the n/s springs. Set slow at 1.25 out and main at 0. Put back together and still flooding. Can see fuel entering from the main while cranking. (didn't think that was right) Compression is at 150 both cylinders. Checked the rotory valve and seems ok.
Checked the coil res and found the primary at 1.9 and the secondary w/caps on at 24.23 K
Looking for some guidance please to avoid to many more tear downs:banghead:
