96 xp carb issues Please help.
chickenman78
I just picked up two 96 xp one ran and one had what the seller said was a blown motor but its was just a blown jet pump. The one that ran had rebuild carbs but always had a flat spot when i hit the gas if pulled the choke it rev fine. So the second ski had brand new crabs swapped them and it runs like a champ. Had the messd up carbs cleaned and new filters installed. The ski all ready had the grey fuel lines change. I now its not the ski because the carbs ran the same on both skis. Ski #2 that runs butt has a flat spot. Has K&N flame arrester and choke removed with primer. I also have a Factory Pipe installed. What pop off pressuare and jet size should i have? When ski was run in the water the flat spot went away when i used the primer to get more fuel to the carbs. Carbs Look like you can eat of them. Clean in and out. Thanks For any info.
