scrapdizle
96 Seadoo SP - Sat for 5 months, Ran fine when parked. I rebuilt the carb (aftermarket kit). It will start sometimes when fully choked and run for a few seconds then die. If i pour premix down the carb it will run forever. I am thinking lack of fuel is the problem. Air leak, Clogged line, Clogged fuel selector? Any tips to help me find the issue? I am going to hook up a funnel to the inet side of the carb and try running it from that to eliminate the carb as the issue. I am also going to remove the return line from carb to see if its pumping correctly. Anything else i should try to find this issue? thanks!
