96 Seadoo SPX (Priced for quick sale!!)
96GSXX
96 Seadoo SPX PARTS (Priced for quick sale!!)
I have everything you need for a 96 Seadoo SPX. Every motor part except crank, and rotary valve assembly! Also have great body and hull parts!
MPEM
Carb
Cylinder Heads
Stator
OEM pistons
Flywheel
Head cover
Exaust manifold
Exaust pipe
Exaust box
Oil pump
Drive Shaft
Jet Pump
If you dont see it listed ask, I more than likely have it
Body Parts
Warning buzzer
Handle bars
Throttle assembly And cable
Choke and cable
Starter and Vts handlebar assembly
Gauges ( work great )
Storage container and purple tubes
Grab bar (black)
Seat (black) excellent condition slight hole in front
A whole lot more just ask too much to list!! Email me at Graham.adams21@yahoo.com! I can upload pictures much quicker from my phone that way!
Thanks!
Hi, I am new to the PWC world and don't know all the lingo. But last fall I traded two jet skis for a motorcycle I had. Well I am just now getting aroung to looking at them and I noticed a chunk of the engine block laying in the bottom of one of them and it's completely seized. I know you said you don't have the crank or the rotor valve assembly(I don't know what that is), but if those are salvagable from mine would you have everything else I need?
Thank You,
and sorry if I sound dumb; I have never owned a boat or anything 2-stroke before
The rotary valve assembly ( can't remember the technical name ) is the the piece that spins the rotary valve and times the engine. The brass gear on mine is stripped (replaceable I believe) and it caused the gear on the crank to sling into the seals. So if your crank and rotary valve assembly are good I have everyother piece to this motor you will need. Everything is in mint condition as it sits now!
