96 Seadoo GTI boggs worse after carb rebuild
esergott
I have a 96 Seadoo GTI, and am having a bogging issue. I had the same problem last year and it went away with a couple quick revs and then its fine for the rest of the day, but now after changing the fuel tank, lines, filter, and doing a carb rebuild it’s a lot worse. I don’t think it’s the fuel selector because it boggs when the fuel selector is on reserve too. It starts up fine and ides fine so I don’t think its engine related, at this point I’m out of ides. I any one has any advice I would appreciate it.
You may have a fuel circulatory problem, or a carb problem. Remove the airbox, and
the supply & return lines from the carb. Put the supply line into an empty bottle and
air chuck a little into the return fuel line. If it flows out the supply into the bottle easily, open gas cap to stop the flow. Its a carb issue. Bills86e
