96 HX revs up when started
Help!! I've done most everything to solve this issue, I'm sure the problem is an air leak in fuel system, changed rotary valve and intake o-rings, carb base gaskets and rebuilt carbs (I'm in denial that it's the crank seals). I did notice a small crack and leak in the oil filter which I will replace tomorrow( it couldn't be that could it? ) When I start the ski up there is no throttle response, It goes straight to red line and thats it. Any suggestions.
