I just picked up a 96 HX. The guy told me that it had sucked up some water and that it would need a total overhaul.
I put a socket on the mag end nut, and tried to turn the motor over, it was stuck tight, but not in the motor. The crand would wiggle nack and forth, and once the motor was out it spins free.
So i got a siezed bearing in the propulsion system.
No biggy I can fix that.
The problem is the motor WAS full of water too. I pulled the heads and found water in the cyclinders. Pulled the cylinders and found water in the crankcase. I dumped the water out, and filled the crankcase full of motor oil.
The water was clean, with no evidence of sludge or anything else. The motor oil I added has turned milky from the water in it. I'll drain it again tonight, and refill.
So it sits as of 15 minutes ago.
My question.
If I hone the cylinders, replace the rings, and reassemble the top end, What kind of a life can I expect from this thing. I got it for the wife, to be used 5-6 times a year for an easy cruise at the local lake. No racing, no high speed running, and freshwater.
The siezure in the back end is another problem I'll address when the time comes.
My question.
