chrismee43
Anyone have a good picture of an installed dual Mikuni Carb showing all the hose connections using a dual feed Mikuni fuel pump. The carbs have been rebuilt and I made the dreaded mistake of not taking a picture before hand.
Post yours, I'm curious as to how that is set up.Is your hook up the same or slightly different. I have a Mikuni dual feed separate fuel pump?
I have had the Mikuni separate pump for a long time and would need to have the carbs changed to have a pulse line connection. It seems like it would be easier to stick with the current setup.No reason to use a separate fuel pump on a stock or even slightly modified 787.
Wow looks like someone made some changes to those carbs. Good Job. If it works I wouldn't mess with it. That could get expensive. LOL Thanks for sharing the pictureHere is the way it looks now.
