eavega
Hey folks
New wear ring installed on my 96 GTX, getting ready to reinstall pump and drive shaft after having sent out the engine for alignment (misaligned engine reason for new wear ring, new drive shaft, new drive shaft carbon seal assembly). When I removed the pump I didn't find any trace of sealant or neoprene ring on the pump or the hull. The service manual does not show the neoprene ring as a part for the GTX, and it doesn't even mention installing the neoprene ring when you do the reassembly (it does for the other models covered in the manual such as the SP, SPX, and GTS). I've read various suggestions on other threads where you do use the neoprene ring, you use silicone instead of the ring, you don't use anything...so now I am confused. What are the recommendations from others that might have done this before?
Thanks.
Eric
Thanks.
Eric
