'96 GTX Low Fuel Sensor? Help!
Bob Payette
I'm new to this forumand have a strange problem, pwc started fine on the trailer, went to launch this weekend and the gas pump light stays on and "low fuel " flashes on and off, won't stop! With out taking it to a shop (I'm unemployeed) what maybe wrong, fuel filter, plugs, sensor? i'm not very up on working on pwc's because there has never been any problem yet that I couldn't fix my self! Help!, any idea's? Thanks!
Bob:ack:
The float magnets may have fallen off, this is common in earlier years, you can see the gas level under the seat right? Search here for the whole thing in detail, plan about half a day so the new plastic cement has a chance to cure well before you dunk it in again, look at the repair pictures because some floats also have a fuse which can be soldered over then you can mount a simple fuseholder outside the tank for better access.
