Matuszak24
96 GTX SeaDoo with all new fuel lines and clean rave valves, I can run great for about 15 minutes before my RPMs start bogging down around 6000 and then at 5500, will bounce down to 5000 and when I open the throttle as soon as it gets to 5500 will bog back down. Runnknf non-ethanol and and fully synthetic XPS. When I shut off the Sea-Doo and let it sit for about five minutes, it will run great for another teip around the lake before it bogs down again. Idles just fine at all times, everything under 5500 is fine. Any suggestions? If it were running too lean or too rich would it run as well as it does for 15 minutes? Has anybody had this issue that is found solutions for it?
IMG_4989.MOV
IMG_4988.MOV
Could this be an issue with the high-speed or low speed screws that I have read about? If so, could someone maybe direct me towards where they are located? Are these screws different than the “jet” screw
IMG_4989.MOV
IMG_4988.MOV
