Ckrawiec
Yesterday while getting the ski squared away (carb issues...finally resolved)....I was running the ski on a garden hose and realized the ski was not really flowing water like it should, the exhaust pipe was getting hot. I shut the ski down but NOT the garden hose.
I pulled the water supply hose from the rear of the ski that connects directly to the cylinder head, assuming I'd get wet and I was ready for it....BUT NO.....No water coming out of the hose.....strange. Upon inspection...the hose was clogged with vegetation, so I poked at with a small screwdriver picking and wedging at it...UNTIL a plug of green schmutz shot out of the hose followed by nice clean water. Shut the hose off, reconnected everything, started the ski and turned on the water......the ski started peeing a nice stream right out the back of the ski....it had never done that before. The exhaust pipe was soon cool to the touch.....the ski was happy again.
This raised a question in my mind.....Is the rear water inlet supposed to be open to the RAW water (lake, river, ocean) with absolutely NO pre-filtration? That seems like a recipe for a disaster. Is there a SeaDoo MALE screw in filter (garden hose fitting) that belongs there?.... outboard of the ski?
NOTE: A while back, I bought a water transfer pump from Harbor Freight and it came with this little (male garden hose screen) that goes on the inlet side of the pump hose....I thought THAT would be absolutely perfect for a SeaDoo raw water prefilter.....it would certainly keep out the bigger schmutz from getting sucked into the cylinder head.
Also, how the heck does the water pressure regulating valve come apart? I can get the cap off, the spring under the cap comes out, but I can't get the rest of the guts to release (they spin freely and move slightly up and down, but won't come loose....and I didn't want to apply too much muscle or toolage in there until I have new parts or better knowledge).
Thoughts?
Thoughts?
