Bflauto
I just got around to testing compression on a 96 GTX that Im fixing up for next year. The original owner said it was tested at 155psi.
I just recently finished doing the oil lines, fuel lines, and a bunch of random fixes. I finally got a compression tester today and attempted to test compression.
I got 73 psi on both cylinders. I am aware that this is insanely low.
I have a nearly dead battery that Im using to turn over the engine. It cranks pretty slow. My question for the smart people... Could a dead battery be the cause for low compression?
The ski starts up and seems to run fine. I've run it on the hose and able to rev it. Would it even be able to run at 73 psi?
I bought a really cheap compression gauge from Amazon. Could it be a faulty gauge, especially since both cylinders read the exact same value?
Any other thoughts?
Any other thoughts?
