MojaveRider
Last year I scored a clean '96 GTI for free, with trailer and title for both. The previous owners had said the last time it was on the water it wouldn't go very fast, but didn't elaborate on what that meant exactly. Since it had been sitting, I assumed it was a carb/fuel problem. I cleaned the gas tank, replaced all the fuel lines, cleaned a lot of junk out of the fuel selector switch, and it runs great. It will start right up and idle out of the water. Took it to the lake, but it had extreme cavitation. Anything about 1/8th throttle would send it right to the rev limiter.
I finally got around to pulling the jet pump off today, and the wear ring is totally jacked. Huge pieces are missing. It doesn't look like debris damaged it, but rather it got brittle and fell apart.
Does the impeller look OK? I don't see much/any damage to it, but this is my first jet pump to pull. I haven't drained the oil yet, but I'm betting it has never been touched. Besides replacing all the bearings/seals in the pump, what else should I look at while it's off?
