mscphillips
Hi guys
my 96 gsx (ive just baught it) wnt rev above idle (i was silly and didnt check it for reving when i baught it)
so far i have
- removed carbs and cleaned
- replaced grey fuel lines
- removed and cleaned raves (btw the oring on these was bigger than the shaft is that normal?)
- set mixture screws
- replaced spark plugs
- checked to see if it runs on res
it runs on premix, the hose to oil pump is blocked off. and the tank was empty that feeds the rotory valve but i filled it up.
also when you hold it WOT it blows fumes out the MAG side carb.
any ideas would be great thanks.
so far i have
