96 GSX 12v lo - spark inside Hull on first turn
nitr0genics
So just finished putting the doo back together after swapping the fuel lines out, when I first turned the engine over there was a spark round the return valve of the Carb, now says 12v lo it did turn again (no spark this time) but then made w clicking sound and displays 12v lo on info centre, any ideas what caused the spark and if the bat is kaput?
Sent from my GT-N7000 using Tapatalk 4 Beta
Just put dess key on and no 2 beeps now just 1 beep if i press start button
Ignore last msg dirty dess key lol tried with a diff bat, spark was there again? Got fuel through n running on revs, think theres still air in system but positive terminal on battery was hot, what coukd be shorting?
Double check all your grounds, put a voltmeter on it and see what your bat voltage is. Its possible your starter is staying engaged and acting like an alternator. I've had that happen on 3 boat motors. 1 caused a fire. Also check all your connections for corrosion and make sure they are tight. Especially the thick cables. Take the ends and give them a 1/4 turn twist. If they break off or have white powder coming out of them, you need to replace the ends.
Check all fuses and report back. If you still have a hot battery, you'll have to perform a parasitic draw test.
how do i check if the starter is staying engaged? all terminals etc are clean and have been double/triple checked now, fuses seem fine
what i have noticed is though, i checked the fuel lines against a guide on here and for some reason my return was connected to pulse and fuel in to return before i changed the hoses and im 99.99% sure i didnt get them mixed up, so the spark is actually at the pulse side of the carb
All solved now thanks for the help birks, turns out the negative terminal was stupid loose on the starter n that was causing the spark, nipped that up got fuel lines connected properly just recharging battery now so should be good to go in a few hours, managed to get it to fire once before battery died from cranking fuel through, but she fired beautifully and held revs perfectly without choke from cold
Thanks for posting back with your solution.
Just popped battery back on after a charge, no 12v lo message but just a clicking sound now not cranking weird
Fixed again lol went back to basics and tapped starter with a hammer all is good pmsl
Stripped it down cleaned it out rebuilt (no new parts) works like a charm fires up first touch like a new ski, 100 times better than when i bought her a month ago just goes to show you should maintain your ski well i uncovered alot of silly little problems most of which wouldnt have been there had the guy before me looked after it
