I own a 96 Challenger and have been having issues, acceleration and my gas gauge does not work which is probably my baffle because the red light works… I’m planning on fixing that soon, I think I might just buy a new one unless I hear I can do it myself I’m not to mechanically inclined but learned through all the post and manual thanks everyone for that. I just replaced the buzzer with one from radiowack great cheap fix… It appears that for some reason the engine is not getting enough gas and I’ve run out of ideas on what it could be.... It gets up to 4, 5 rpms and then dies down not wanting to jump out of the water. I had the same problem last year but one day it just went away because i moved the switch to reserve tank??? But that wasn’t the ultimate solution cause that stopped working…. So, here is what I have done to the boat as far as troubleshooting goes. Carbs rebuilt last year, RAVE vales cleaned last year, pump oil changed last year, fuel filter cleaned yesterday again no issues there... fuel line are not gray and are in good shape. Checked the wear ring its good no bad signs or scrapes… I normally fill 87 but I filled 93 yesterday thinking I could be old gas from winterizing but turns out that not the case… Took the flame arrestor off yesterday carbs look clean and still have the golden color .. Sorry for the long post I just wanted to make sure I hit all the points that I’ve tried before I get info back…. I really don’t want to take it to the shop if I can take care of it myself.
Please Help!!!! Thanks
