Hi Paul,
just being a bath is a load off my mind, well, as usual, all worked up over nothing.
As to fuel lines, it was the first thing I did after reading about them on this site and was so glad that I had looked around for info.
I did have a carb fitting or two snap off when I was trying to get the exhaust off because the carb bolts were frozen and had to remove the exhaust manifold to grind the head off of 2 carb bolts, all that so I could replace the lines on top of the carbs. While I had the carbs off I cleaned the carb filters and took them by a local small engine shop and had them look at them and they said inside of the carbs looked good to be as old as they are. But with that said the ski has only got a 178.4 HRS on it so I'm sure the low hrs helped a lot.
But all that work was really a good thing because as soon as I unbolted the exhaust and got the pipe out of the way I spotted a few acorn shells left by squirrels so I got a mini cam and looked around inside the motor and, oh yea, they were everywhere but was able to tape a smaller hose onto a shop vac and got it all, or so far so good.
As we speak I am starting a leak test to ensure I have a good seal on the motor before I tweak around on the carbs to try and adjust the 1100 or so RPM's out of the idle.
And yes there is a slight slack in the Throttle cable.
Is there anything you can think of that could be a pitfall at this point I may be overlooking?
And thanks for the info on the oil lines.
