Seadooojetski
Hi so recently I got a 1999 xp limited that’s wasn’t running and after fixing it, it has very slow acceleration. I rebuilt the carbs with genuine mikuni kits, set the pop offs at 21 psi and deleted the accelerator pump with 165 main and 95 low. 1 1/2 turns out for the low speed and 1/4 for the high. Stock air box and sea level. Cleaned the rave valves although I haven’t checked the solenoid to see if it’s working or replaced the lines for them. The low end seems to be the only thing affected, after the powerband hits it pulls very nicely and tops around 55 on somewhat choppy water. When racing against my friends gp760 it destroys my ski out of the hole. At wot it revs to about 4K quickly then very slowly to 5k until the powerband takes over. Also at wot it only gets up to about 6500 rpm’s on choppyish water. Running 40:1 premix xps. Thanks for any help.
