95 XP 800 Drive Shaft Bearing Gets Boiling HOT
pad96
I have A 95 XP 800 I just rebuilt the motor put it back in and Aligned it with the alignment tool and now when I run it the bearing get so hot it will boil water and its a brand new bearing. Why is this happing could my drive sahft be bent? or am I over looking something else
Are you SURE you have the alignment right? What kind of oil did you fill the cap with? Ive seen a plastic pump melt down..
Im pretty sure the alignment is correct im going to tear it apart again to check it and I used the sea doo synthetic oil in the cap other then it still being out of alignment is there any thing else that can cause this?
