PolarCelsius
Put a fresh engine rebuild in the ski (oil line failure) didn't rebuild the carbs but did replace *most of the grey fuel lines
Engine hesitates to accelerate RPM wise with WOT, doesn't feel like cavitation as RPMs take a moment to rise, once at speed, after 6k RPM it runs rough as if it's running very very rich, doesn't feel like it used to, not powerful enough
While replacing the engine I noticed the oil pump lever was below spec (the lines lining up to each other) so I raised it to spec, richening the mix
Could it be the carbs?
Could it be the voltage regulator rectifier?
Could it be that small adjustment I made to the oil pump?
