I have a problem with one of my engine. One seem to stop @ 6000 RPM. The other go up to 7000 RPM. I know it might be a MEM problem that could cause this. The speed limit in forward or reverse is 7000 RPM and 3500 RPM in neutral. I can test this by disconnecting the tach wire to the MEM. I like to know if there is another reason or reasons for this. Note the engine has good compression and starts and runs fine. No fouling plugs ands runs fine for hours. Also can someone explain how the speed limiter circuit works. (how those it cut the spark/power to the plugs)
